is this swap possible?
Old Sep 30, 2007 | 10:34 PM
spudsterier's Avatar
spudsterier
Default RE: is this swap possible?
ORIGINAL: bone33
i said it like that cuz you know the newbie f-tard wont even be back to look.
i find that comment really funny because he has actually been a member of this forum longer then you[sm=boink3.gif]
Old Sep 30, 2007 | 11:45 PM
pssssst's Avatar
pssssst
hahaha
Old Oct 1, 2007 | 04:50 PM
neonrob's Avatar
neonrob
dose n e one here know if i can swap the head off a 98 dohc to a 96 sohc block? ... or is it better just to swap the whole motor?
Old Oct 1, 2007 | 05:08 PM
Aerorat's Avatar
Aerorat
Yes just have to make sure see if the connectors are the same or you may have to splice them to match the head
Old Oct 2, 2007 | 02:20 AM
unclemike's Avatar
unclemike
What about the extra timing belt pulley? Or does the SOCH block have the bosses to mount it? I got a DOCH with a bad bottom end and an SOCH that is running and inspected.
Old Oct 2, 2007 | 02:28 AM
12 volt's Avatar
12 volt
same block diffrent pistons. DOHC head on a SOHC block gives you lower compression
http://www.allpar.com/mopar/2.html
read up
Old Oct 2, 2007 | 02:36 AM
12 volt's Avatar
12 volt
https://dodgeforum.com/m_902568/tm.htm
more good stuff
Old Oct 6, 2007 | 12:11 AM
noenwarrior's Avatar
noenwarrior
you also need dohc motor mount braket becare ful i attempted this and snapped 4 valves in have my screw up lol.
