engine and tranny lifts and engine upgrades
Old Sep 30, 2007 | 09:40 AM
thaguamanian's Avatar
thaguamanian
Default engine and tranny lifts and engine upgrades
any suggestions for what type of engine and tranny lifts??? AND how much does the engine weigh? how about the tranny? when i get my neon back in either the end ofoctober or beginning of january, i'm going to start building the engine and i want to swap the tranny for a mtx.
What kind of power am i looking at if i do the following upgrades:
(from modernperformance.com) http://www.modernperformance.com/dcx/PL95_index.shtml
DOHC (Dual overhead cam engine 1995-1999 Neons)
[ul][*]Stage 1 -Replace restrictive stock intake with a high flowing intake (Iceman or Kirk) [*]Stage 2- Replace heavy, restrictive crankshaft pulley with lighter, smaller pulley (MPx, or Unorthodox pulley) [*]Stage 3- Have intake manifold processed by Extrude Hone.
(due to the DOHC responding very well to intake modification, we feel that the extrude hone process belongs at #3.)
[*]Stage 4- Replace stock exhaust manifold with Kirk header for higher gas flow output [*]Stage 5- Install large bore TB for higher air flow into engine from intake.
(MPx Billet TB) and port match the intake manifold.
[*]Stage 6- Install prothane motor mount inserts, rear bobble strut, install new spark plug wires and MSD computer. [*]Stage 7- Install rear muffler (Vibrant, Thermal, Borla exhaust)[/ul]
It's going to cost me about $1,004 for the parts. I already have a full exhaust system. megan header, new cat(standard), new pipes(2.25 i think, maybe 2.5), and aftermarket stock muffler(i got tired of getting tickets with my aftermarket "ricer" muffler). And a ebay/"home made" CIA. I'll be doing the installing. For stage 3, should i get the INDY intake manifold http://www.modernperformance.com/dcx...manifold.shtml??
Old Sep 30, 2007 | 01:22 PM
12 volt's Avatar
12 volt
Default RE: engine and tranny lifts and engine upgrades
http://toolsteal.com/index.php?cat_i...p;prod_id=4332i wouldnt pay more that 300$ for an engine lift, sometimes you can get some good deals a checkers or autozone.
