quickest way to remove head
Old Sep 29, 2007 | 11:06 AM
pssssst's Avatar
pssssst
Default quickest way to remove head
hey sorry to post a probably beatin topic but im runnin out the door to work and wanna have something to read when i get home.... im taking my sohc head off tomorrow and wanna know the quickest way to do it... thanks!
Old Sep 29, 2007 | 01:02 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Default RE: quickest way to remove head
There is no quick way to do it, it is all straight forward. Here is a write up I did on it:
https://dodgeforum.com/m_912413/tm.htm
Old Sep 29, 2007 | 11:21 PM
spudsterier's Avatar
spudsterier
easiest way: unbolt it
Old Sep 29, 2007 | 11:50 PM
pssssst's Avatar
pssssst
ORIGINAL: spudsterier
lol that wouldbe sweet if u could just remove a few bolts and pull it off with no problems
Old Sep 30, 2007 | 12:36 PM
mr340's Avatar
mr340
Muscle Car Moderator
Actually, I think 3 gallons of oil in the crankcase, and 30 minutes of redline, and the head should excuse itself from the engine bay without turning a single wrench...
Old Sep 30, 2007 | 03:20 PM
Jellysrus's Avatar
Jellysrus
dumb question so you can put everything back together but what about not even doing a vale job woukd it be ok to just take it apart replace gaskets clean it and put it back together??
Old Sep 30, 2007 | 03:32 PM
Jr. Mechanic
ORIGINAL: Jellysrus
You can, it is not recommended though. You cannot always be sure of the condition of the head, so it is best to send it to the machine shop or get a reman, but I usually just do a good cleaning and valve job.
Old Sep 30, 2007 | 04:09 PM
12 volt's Avatar
12 volt
remember to prelube everything before assembly.
