ignition problem??
Old Sep 30, 2007 | 04:56 PM
jfink's Avatar
jfink
Default ignition problem??
about a year back i accidentaly cut the middle wire going to the coil and have had ignition problems along with the check engine light ever since. i've tried plice connectors, solder, even male/female wire connections but to no preveil. need help tired of my car stalling throughout the RPM range.
Old Sep 30, 2007 | 11:21 PM
12 volt's Avatar
12 volt
Default RE: ignition problem??
it souldent matter how you splice the wires.... as lang as you have continuity on the wire it sould be fine. Maybe the problem is somewhere else, did you pull the fault codes form the CEL ?
