rooling toPulling
Old Sep 30, 2007 | 08:05 PM
RiceBoy_88's Avatar
RiceBoy_88
Default rooling toPulling
When I push my brakes it will pull to the right,but it also feels like it is rollingto the right really bad.I put new braked on but it still does it. Any info will help...
Old Sep 30, 2007 | 08:07 PM
95to96transplantneon's Avatar
Default RE: rooling toPulling
Bleed your brakes to start see if that helps...
Old Sep 30, 2007 | 08:15 PM
RiceBoy_88's Avatar
RiceBoy_88
ok thanks
Old Sep 30, 2007 | 08:21 PM
Just guessing you have air in your line on the left side from when you changed you brakes or from before that and the air made its way down to the caliper
Old Sep 30, 2007 | 08:24 PM
tattoojack's Avatar
tattoojack
if you are getting pulling to the right even when hot braking, get your front end aligned.
Old Sep 30, 2007 | 08:30 PM
RiceBoy_88's Avatar
RiceBoy_88
It only pulls whenI push on my brakes.
Old Sep 30, 2007 | 11:18 PM
neoncrazy101's Avatar
neoncrazy101
could be one of your calibers sticking a little bit. or just sending more pressure it than the other...so aka bleed.
