Questions
Old Oct 1, 2007 | 11:42 PM
kokujo's Avatar
kokujo
Default Questions
Ok I'm rebuilding my 2.0L engine for turbo, cuz I hear that the 2.0L can run faster then the 2.4L turbo from the srt-4. First off how would I run a press start engine button?? Also could I put the 2.4L pistions from thesrt-4in the 2.0L??
Old Oct 2, 2007 | 12:08 AM
12 volt's Avatar
12 volt
Default RE: Questions
2.4 pistons will not fit in a 2.0
Old Oct 2, 2007 | 12:24 AM
kokujo's Avatar
kokujo
I was told that the 2.4L, and 2.0L has the same bore.
Old Oct 2, 2007 | 12:37 AM
12 volt's Avatar
12 volt
wow i guess they do have the same bore. My mistake some how i remember someone saying they woudent fit for some reason.
Old Oct 2, 2007 | 12:42 AM
kokujo's Avatar
kokujo
Well I was talking to my friend and he was saying something about how the pistions and the one things hook up at are different?? Which I don't see why they would make it different for the 2.0L and the 2.4L
Old Oct 2, 2007 | 01:51 AM
unclemike's Avatar
unclemike
Try compression height or pin bore height. The piston might have the same bore diameter but the pin bore will be higher or lower and the skirt will be longer or shorter.
Old Oct 2, 2007 | 08:38 AM
das2123's Avatar
das2123
ORIGINAL: kokujo
They do not have the same bore.
Click the link for a push button starter how-to...
https://dodgeforum.com/m_576886/tm.htm
Old Oct 2, 2007 | 10:34 AM
spudsterier's Avatar
spudsterier
the srt4 pistons will NOT work in a 2.0
Old Oct 2, 2007 | 12:17 PM
Aerorat's Avatar
Aerorat
Build for build the srt 4 2.4 will out power out torque the 2.0
