motor
Old Oct 3, 2007 | 11:24 PM
kingof97neon's Avatar
kingof97neon
Default motor
ok heres the deal ok neon has broke down and i am going to put a new motor in it and i am wanting to know if i should go turbo or all motor
which one would cost more
i like turbo my self but i have been thinking about going all motor
its an everyday driver cuz i just sould my honda crx
anyones help would be great
thanx zack
Old Oct 4, 2007 | 03:43 PM
tattoojack's Avatar
tattoojack
Default RE: motor
if its your daily driver, all motor would be less maintainence. turbos take alot of tunig to get just right. and with all motor you dont have to worry bout the psi blowin your motor again.
Old Oct 4, 2007 | 04:13 PM
spudsterier's Avatar
spudsterier
Default RE: motor
you dont have to worry about the boost blowing anything up if:
1: its built right
2: its tuned properly
3: you run low boost
all motor would be nice, but if your wanting alot of power then the turbo would be cheaper
Old Oct 4, 2007 | 04:53 PM
Aerorat's Avatar
Aerorat
Default RE: motor
most here know my opinion and i am not going to be excused of turning this into a srt 4 swap [8D]
Old Oct 4, 2007 | 07:44 PM
kingof97neon
Default RE: motor
so turbo would be cheaper then the all motor i was told that on stock bottom end not to run more then 7 psi andno one around here knows **** there all honda people
Old Oct 4, 2007 | 10:25 PM
spudsterier
Default RE: motor
no you shouldnt run more then 7psi......but even that much on a stock bottom end and i was able to beat stock srt4's
