painting rims project
Old Oct 19, 2007 | 03:54 PM
civiceater88's Avatar
civiceater88
Default painting rims project
what grit sand paper should i use to paint my wheels
Old Oct 19, 2007 | 06:12 PM
95neonriceeater's Avatar
95neonriceeater
Default RE: painting rims project
ask das, he painted his "riams"
Old Oct 19, 2007 | 06:29 PM
pssssst's Avatar
pssssst
if your not going to primer just use a 1000 grit to rough the surface then paint over that
Old Oct 19, 2007 | 09:00 PM
civiceater88
what if im going to primer?
Old Oct 20, 2007 | 12:09 PM
unclemike's Avatar
unclemike
What kind of rims? Aluminum or the stock steel?
I did my stockers with cheap black paint. First I cleaned the rims thoroughly with Castrol's cleaner and a parts cleaning brush. This took off 9 years worth of road grime on both sides. The inside finish looked like new. Then I sandblasted the rust spots on the outside, filled my spraygun with cheap lacquer thinner and sprayed them down. I painted the wheels and set them aside for a few days for the paint to set up then mounted my new Bridgestone 190/60x14 tires.
