urgent need some help...
Old Oct 22, 2007 | 07:25 PM
reaperof_evil's Avatar
reaperof_evil
Default urgent need some help...
ok i can get a 2nd gen 2.0 sohc head for 50 bucks with everything with it ready to bolt up will it bolt to my 97block reason i want to do it is becuuse my head is going and rapping real bad and the cam seal is going and i think a valve is bent will a new head bolt right up??? please let me know asap so i can go tommorow
Old Oct 22, 2007 | 11:45 PM
mulletman11's Avatar
mulletman11
Default RE: urgent need some help...
let u no wat?
Old Oct 22, 2007 | 11:55 PM
reaperof_evil
will a 2nd gen head work on a 1st gen block
Old Oct 23, 2007 | 12:45 AM
pssssst's Avatar
pssssst
umm...i dont think it will but somebody else needs to back me up cuz im not 100% sure
Old Oct 23, 2007 | 12:49 AM
mulletman11
yea i dont think so either
the 2nd gens used a dif motor i belive (das dont quote me)
like the 2nd gen rts used a 2.0 magnum engine instead of a 2.4 so no, i dont think it will work
Old Oct 23, 2007 | 12:57 AM
Slashwannabe's Avatar
Slashwannabe
The Second generation2.0 SOHC is the same engine we have in all our Neons with the exception of a hotter cam and improvedintake manifoldand Throttle body. This engine lasted from 1993 to 2005 and ended with the Neon.
Yes that head will work and you'll bennifit from a better Cam and a bit better flow, but it will bolt right up!. My advice is go for it and if you don't totally beleive me I will buy the head from you or whoever is selling it .
The Magnum name is given to almost all Engines used by Dodge, The block is the samecasting#and the head is almost identical to the first Gen 2.0 only difefrence is better cam and improved flow.
Old Oct 23, 2007 | 10:54 AM
das2123's Avatar
das2123
ORIGINAL: Slashwannabe
It is only a better head IF it's a Magnum head, which the original poster did not mention.
But to answer the original question, yes it will work fine. You won't have the EGR anymore though however if you have emissions testing and you may get a CEL for it.
Old Oct 23, 2007 | 09:27 PM
reaperof_evil
when i went to the yard to pick up the head the entire car was gone kinda made me die alittle inside but i found a set of tokiko struts brand new in the boxes in the trunk of a neon 26 bucks for both
Old Oct 23, 2007 | 10:59 PM
jimustanguitar's Avatar
jimustanguitar
what do you mean, its rapping really bad? is this a noise that it makes, or did you mean that it is warping?
Old Oct 24, 2007 | 03:08 PM
reaperof_evil
no it taps like ever neon i ever seen besides the 2nd gens and i dont like driving around with a nice looken car and have the engine knocking like a piece of ****.
