neon cuts out during rev
Old Oct 25, 2007 | 04:12 AM
raymond4000's Avatar
raymond4000
Default neon cuts out during rev
Hi,
I have a 1995 dodge neon. The car starts right up and idles great. When I go to rev it up it cuts out badly, however when I drive it down the road or highway it seems to run fine and pull itself well. Any ideas? I did notice that the check engine light was on as well. I am wondering if this issue is just a bad throttle position sensor or something similar. Appreciate any input.
Ray
Old Oct 26, 2007 | 08:40 AM
das2123's Avatar
das2123
Default RE: neon cuts out during rev
Could be TPS or IAC motor. Pull the codes and see what it tells you.
