1997 neon upgrade questions
Old Nov 1, 2007 | 05:24 PM
stevenb's Avatar
stevenb
Default 1997 neon upgrade questions
I'm new to the Dodge forums. I just bought a 1997 neon, 3 speed automatic, 4 cylinder. I would like convert it to a 5 speed manual and add some other stuff such as cold air intake, and a turbo. I'm not very car inteligent, so try to break it down for me if this is all possible and how i would go about doing it. Thank you.
Old Nov 1, 2007 | 07:32 PM
tattoojack's Avatar
tattoojack
Default RE: 1997 neon upgrade questions
if you arent very car intelligent, this is gonna be hard.
remove the ATX, install MTX
install clutch pedal setup, run cables
remove center console, remove ATX shift setup
install MTX stick setup, run cables.
adapt any sensors, you may have to change pcm? not sure.
still interested? if not,
sell your car and buy MTX. easy!
