remote mounted turbo
Old Nov 5, 2007 | 06:23 PM
hatchetman2590's Avatar
hatchetman2590
Default remote mounted turbo
is it possible to have a remote mounted tubo on a neon and if so, wat is the advantage of having one?
Old Nov 5, 2007 | 07:13 PM
Slashwannabe's Avatar
Slashwannabe
Default RE: remote mounted turbo
Its possible to mount it right on top of your transmission where the battery sitsbut as to why somebody would be that high or on crack or retarded I wouldn't know. Right on the engine exhaust manifold is the best, saves room and un needed complication of exhaust pipeing.
Old Nov 5, 2007 | 09:13 PM
hatchetman2590
ok the reason y i was asking was because the corvette has it mounted rite above the bak axel as does my friends dodge ram1500
Old Nov 5, 2007 | 10:48 PM
95to96transplantneon's Avatar
Is this what you mean???
This is the only way ive seen it done personally...
(note: this is not my car its called the black widow)
Old Nov 6, 2007 | 12:22 AM
boxerjl2's Avatar
boxerjl2
that looks cool
Old Nov 6, 2007 | 01:14 AM
12 volt's Avatar
12 volt
More efficient if you go conventional but im sure it can be done. all it takes is time and money
examples of rear mounted
http://www.svspower.com/case_study_detail.aspx?id=19
http://www.vetteweb.com/features/vem.../photo_13.html
http://www.jlturbo.com/benefits.html
