My 99 dohc just threw a P0304 code. Any thoughts?
Old Nov 12, 2007 | 08:55 AM
das2123's Avatar
das2123
Default RE: My 99 dohc just threw a P0304 code. Any thoughts?
Do you have a DOHC or SOHC?
Old Nov 13, 2007 | 01:54 AM
Hawc's Avatar
Hawc
Ireplaced the intake manifold gasket today. Idle is perfect andpower isback. I have a feeling it's been leaking for awhileuntil itfinally got bad enough to cause a misfire. New gasket material issuperior tothe crappy oem gasket. A bit of a pain to do but at least the problem is solved.
Das2123:dohc
Old Nov 13, 2007 | 08:23 AM
das2123's Avatar
das2123
Good to hear your problem is solved. I have heard of manifold gaskets causing misfires.
