computer help
Old Nov 13, 2007 | 10:06 AM
spudsterier's Avatar
spudsterier
Default RE: computer help
there are more differences between the sohc pcm and dohc pcm then just the timing
Old Nov 14, 2007 | 08:10 PM
93 tona's Avatar
93 tona
so what im being told is that its useless to try to do the swap, because no one can find the computer, and there is no other way of doing it huh. has ne one tried splicing a 96 computer into a 95? or is there some other ecu i can use... what about the mopar one, like if i go with one of those, i wont be able to use a turbo right so is that option out the door?
Old Nov 15, 2007 | 02:19 AM
95to96transplantneon's Avatar
hey tona I emailed a few guys i know in the community to see if they can track one down for you. They are pretty hard to find, but one guy lives like 50 miles away from the neoprenza guys and they have about 60 ecu's laying around there barn...maybe you will be in luck... If i get an email back I will let you know.
Old Nov 15, 2007 | 04:38 AM
12 volt's Avatar
12 volt
i have one...... ill try and take some pix if your interested
Old Nov 15, 2007 | 08:26 AM
das2123's Avatar
das2123
^^^Buy his!!!
