computer help
Old Nov 7, 2007 | 12:33 PM
93 tona's Avatar
93 tona
Default computer help
hay ppl got another neon. its a 95 sohc i was going to do my 2.4 swap with the 96, but since emissions is a deal for that year but not the 95, i am going to choose to do the swap in the 95. only problem is i cant find the DOHC MANUAL computer...any help would be nice
Old Nov 7, 2007 | 01:21 PM
spudsterier's Avatar
spudsterier
Default RE: computer help
a dohc manual pcm for a 95 is about the hardest1 to find
Old Nov 7, 2007 | 01:27 PM
12 volt's Avatar
12 volt
ill sell you a 2.0 DOHC PCMif you have problems finding one
Old Nov 7, 2007 | 02:20 PM
95to96transplantneon's Avatar
thats what he needs as long as it is a 95 and has one long connector
Old Nov 8, 2007 | 09:42 AM
das2123's Avatar
das2123
Emissions aren't a problem for the 2.4 swaps in the neon that I know of.
Old Nov 11, 2007 | 12:20 AM
93 tona's Avatar
93 tona
if you got a 95 ill take take, i cant find on anywhere, and its the only hing holding up my swap. and the 2.4 doesnt affect my emissions, buti have deleted my cat and egr system so i want to just keep all the illegal stuff on one car.
Old Nov 11, 2007 | 12:02 PM
unclemike's Avatar
unclemike
Depending on the state where you live if the computer starts throwing codes it won't pass inspection. They don't check for codes on OBD I cars here in PA. My daughter's 1996 was throwing a misfire code that wouldn't clear and wouldn't pass. The mechanic told me to disconnect the battery for 24 hrs then bring it back.
Old Nov 12, 2007 | 04:08 PM
93 tona's Avatar
93 tona
in MO, if the check engine light is on it wont pass... but since i got a 95, i dont need emissions. Thats why i switched from my 96 project, and gave it to my grandma. Boy does she like it. Neway, all im looking for is a DOHC?manual trans computer out of a 95 neon. its different because it takes one long conector strip instead of 2 short ones like the rest of the years. I am doing the 2.4 swap and thats all i need is that da*n computer, i cant find one anywhere. Is there another way around it...can i use someother EMS(engine management system) has anyone converted a 95 computer to a 96, through cuting and splicing... Is there such a thing as a DOHC/manual transneon in 95?any heelp would be gratefully appreciated
Old Nov 12, 2007 | 04:11 PM
93 tona's Avatar
93 tona
oh yeah what exactly happens if i put my 2.4 in with a sohc computer. and is there a way of countering it. like if it retards, could i get adj. cam sprockets, and advance the timing?
Old Nov 13, 2007 | 08:14 AM
das2123's Avatar
das2123
I do believe you need the DOHC PCM...don't know anyone who runs the SOHC PCM with the 2.4 swap.
