wel i think its official
Old Nov 9, 2007 | 09:59 AM
  #21
das2123's Avatar
das2123
Default RE: wel i think its official
ORIGINAL: 96ACR*
how much for all the turbo stuff?? and would it be a good idea to run on my car..it has 130 000 KM
Check your compression first and make sure you have NO oil leaks.
Old Nov 9, 2007 | 10:31 AM
  #22
spudsterier's Avatar
spudsterier
im not sue on a price...im gonna dig into it soon and i will let you know if i deide to go through with this
Old Nov 9, 2007 | 05:28 PM
  #23
hatchetman2590's Avatar
hatchetman2590
hey spud, wat kind ofwing is on there
Old Nov 9, 2007 | 06:08 PM
  #24
spudsterier
just a stock neon one
Old Nov 9, 2007 | 08:10 PM
  #25
96ACR*'s Avatar
96ACR*
ORIGINAL: das2123
ORIGINAL: 96ACR*
Ok will do.. i would only be able to run around 8 psi at max eh?
Old Nov 9, 2007 | 09:05 PM
  #26
99 Neon's Avatar
99 Neon
ORIGINAL: 96ACR*
ORIGINAL: das2123
ORIGINAL: 96ACR*
I have 64k on my car and when i turbo it im only gonna be running 8psi 10 tops
Old Nov 9, 2007 | 11:39 PM
  #27
spudsterier
on a completely stock internal motor, 8psi would be the best for prolonged use, but get a boost controller and you can run 10psi every once and a while to save the motor...
running a turbo on a stock motor greatly reduces the life of the motor...mostly if its not tuned properly....
on a good note,
i got the red r/t working again.....ends up the 4 bolts that hold the clutch to the flywheel rattled loose....well, 3 were loose and 1 fell out and got jamme in the starter....
so i tightened them all back up and now it runs like a champ......
i think what i might do over the winter is to scrap all the turbo stuff and build an all motor car....maybe sooner...
Old Nov 9, 2007 | 11:46 PM
  #28
95to96transplantneon's Avatar
Allmotor is awsome, I drove a buddy's k24 with a k20 headswapped 96 civic si, that has about 10000 in the motor. He's pushing just under 300whp NA power. And I sware you bearly touch the gas and your gone, the throttle responce is just sick as hell.
Old Nov 9, 2007 | 11:47 PM
  #29
96ACR*'s Avatar
96ACR*
i would like to get a hold of your turbo stuff if possible??
And would i need to get a shop to tune it?
Old Nov 9, 2007 | 11:55 PM
  #30
spudsterier
you would need a shop to properly tune it....unless you get a good air/fuel gauge, then you can do a pretty good job yourself....
if i go all motor then i wanna get the 12:1 je pistons, use the crane #14 cams i alredy have, mopar pcm, iceman intake, borla exhaust, and a few other bolt ons...but i will haveto see when i would have time to rip it all apart and get all this other crap
