projectors in...halos arent working right
Old 11-10-2007, 05:43 PM
justinsanders's Avatar
justinsanders
justinsanders is offline
Default RE: projectors in...halos arent working right
ok thanks. is your low beam halo not as bright as your high beam because my low beam halos are noticablly dimmer than the high beam's halos.
Old 11-11-2007, 01:34 AM
spudsterier's Avatar
spudsterier
spudsterier is offline
no mine are the same brightness
Old 11-11-2007, 09:10 PM
justinsanders
o. well thats not good
Old 11-12-2007, 12:06 PM
protivakid's Avatar
protivakid
protivakid is offline
did you get your halos working with the turn signals? When I was wiring up my mirrors I realized that if you wire up lead to lead and grnd to grnd they only come on when your lights are not one. When the neon's lights are on the connection is switched so if you want your halos to come on with your parking lights I had to wire them up lead to grnd and grnd to lead in order for the side mirrors to work with my lights at night.
Old 11-12-2007, 03:32 PM
justinsanders
o really? ok thanks ill try that too
Quick Reply: projectors in...halos arent working right
