projectors in...halos arent working right
Old Nov 8, 2007 | 08:17 PM
justinsanders's Avatar
justinsanders
Default projectors in...halos arent working right
i have 3 fairly easy questions.
where do you wire up the halos. i want them to come on with the parking lights. i have them wired to the corner lights but they only come on when the blinker is on. they wont come on with the parking lights. ive also noticed they wont come on when the headlights or parking lights are on even though the blinker is on. there is 3 wires going to the corner light, i have 2 on the halos so im guessing i should splice into the other power wire so they will come on when the parking lights are on.
the bulb size for the stock fog lights is 881. can you use the 880 or 882 in there? the only difference is that those are like 50 watts as opposed to 27. will they be brighter? if so then ill just get those.
it seems like the projectors are wired backwards with the high and low beam. when the low beam is on the inside lights are lit up then the high beam is on the outside light come on. is this right. it doesnt seem like it but theres only one way for the plug to plug in so i know thats wired right.
[IMG]local://upfiles/63489/14D67942C93B4177BD1CF7E33F1E6BFE.jpg[/IMG]
[IMG]local://upfiles/63489/85935D6A002946E2BB4C80B116AFA2B7.jpg[/IMG]
Old Nov 8, 2007 | 08:35 PM
spudsterier's Avatar
spudsterier
Default RE: projectors in...halos arent working right
i have my halos hooked up to the power wire on the front turn signal....they come on when the parking lights and headlights are on....
as for the headlights, if they are like mine then you can just swither the plugs around and make the inners and outters switched.....but you should be able to tell which ones are brighter...
now for the fog lights...i have been asked this question before....
you might be able to use the higher watt bulbs, butif they are a higher amperage, then you can blow the fuse of melt the wires.....also, higher wattage lights give off more heat...im not positive if the fog light housings can hold up to alot of heat or not....
the way i look at it, those wattage bulbs were used for a reason......
Old Nov 8, 2007 | 09:51 PM
justinsanders
ok. ill just stick with the 881s then. my halos are also spliced into the front turn signal thing but they only come on when the blinker is on. im guessing i just have to use the other power wire insted of the one im using now. and my projectors are like yours but are you sure i can just simply flip the plug around for it to work? i thought that the plug was shaped for only one way and the clip is only on one side.
Old Nov 8, 2007 | 11:43 PM
spudsterier
as far as i can remember, the plugs are switchable.....
i forgot what wire i used for the power on the halos, i wanna say black with a blue stripe, but im probally wrong....i can always check tomorrow if you want me too......
Old Nov 8, 2007 | 11:48 PM
mulletman11's Avatar
mulletman11
congrats on ur moderator status
Old Nov 9, 2007 | 12:05 AM
spudsterier
ORIGINAL: mulletman11
well thank you....im just here to help
Old Nov 9, 2007 | 12:38 AM
iwalton63's Avatar
iwalton63
as for the halos... yeah just switch the wire you have it slpiced into. or if you want to you can just extend the wire alittle bit and wire it into to side markers on the bumbers.
Old Nov 9, 2007 | 03:25 PM
justinsanders
ok thanks everyone. and ill just got out there and switch the wires real quick. hey spud is your outside lights the low beam or is your inside light your low beam? also the halo isnt as bright on the outside lights for some reason. any one kno why?
Old Nov 9, 2007 | 04:56 PM
spudsterier
im not sure which ones are high beams....im thinking its the inside ones, but im not positive.....im going out in the garage in a few minuites so i will check and let you know
Old Nov 9, 2007 | 11:58 PM
spudsterier
inside are high beams....outside are low beams
