GO 2.4 OR GO HOME
ORIGINAL: Sixtysixdeuce
Merlins (Chevy BB-based) can go 632 inch (10.4L) and there's now an 830 inch (13.6L) Ford-based V-8. Mopar's biggest is the 528 Hemi (8.7L).
i don't think the 2.4 is the best example of a super engine they make engines way above 7.0
I've seen 600hp 2.0SOHC Engines so I dont think the 2.4 is the end all be all, but it just takes less effort to get to 600hp with a 2.4. The way I look at it is if I need more than 300hp out of my Neon Then the 331Hemi is going into it.
ORIGINAL: Jellysrus
oki read some and people want to know why you just dont put a turbo on my 2.0 because i have 160k on the motor and the srt 4 only has 38k and i have to tools and everything that i need to do the swap
???where do i have to cut the frame for the srt 4 tranny anyone have pics well and another thing that i did not understand is if i have the pcm from the srt 4 can i use it???
SENTRY KEY IMMOBILIZER
MODULE and the key and turning barrel. All three the pcm, key, S.K.I.M. need to be from the same vin number
