2 questions.
Old Nov 19, 2007 | 07:56 PM
estneon's Avatar
estneon
Default 2 questions.
i was playing with my car and as some might know i now have no a/c(not that it worked)...anyways i had to remove the belt to the powersteering and the a/c. soi was driving it with out power streering and it's not so bad. so my first question ishow do you remove the power streering the proper way? now for the last question whats thecons (problems) of removing the powersteering....i would look it up but im very verybusy so i can't right now
Old Nov 19, 2007 | 08:41 PM
spudsterier's Avatar
spudsterier
Default RE: 2 questions.
remove everything power steering related and then take the 2 lines that come off of the rack and hook them together.....
cons:
no powersteering
Old Nov 19, 2007 | 10:36 PM
estneon's Avatar
estneon
thanks spudi'll play with that sometime this week
Old Nov 20, 2007 | 01:16 PM
tattoojack's Avatar
tattoojack
also remove the a/c compressor, the thin radiator in front of your radiator that the lines connect to, the a/c bracket, and if you really wanna get wild, remove the dash and take out the a/c lines and the condensor or whatever its called inside the dash.
