ok I got a tire Question....
Old Nov 20, 2007 | 06:05 PM
Slashwannabe's Avatar
Slashwannabe
Default ok I got a tire Question....
Ok I have a set of 15 inch rims, I have my15s successfulyon the back of the car with 205/75s. My question is... On the frontwhat tire size can I put on my 15 inch rims that won't screw up the speedometer and rub on the fender wall? I understand it will have to be a lower profile tire but I'm not sure what the size is. I would like to make the car match as far as mags go.
My 15' magsare originally off of a 1990 Daytona.
Old Nov 20, 2007 | 06:09 PM
tattoojack's Avatar
tattoojack
Default RE: ok I got a tire Question....
same as rear.
i had 17's with those size tires. no rub.
Old Nov 20, 2007 | 07:19 PM
Slashwannabe
Cool thanks,
Was your Speedometer spot on?
Old Nov 20, 2007 | 09:05 PM
spudsterier's Avatar
spudsterier
your best bet if you want the speedometer right on would be to run a 205/55
Old Nov 21, 2007 | 12:12 AM
Slashwannabe
Thanks Spud I appreciate very much.
Old Nov 21, 2007 | 12:15 AM
unclemike's Avatar
unclemike
Go to Tire Rackand check out the engineering specs for the size tires you want to run.
Old Nov 21, 2007 | 08:31 AM
mmench's Avatar
mmench
i run 205/40's on my 17's and get a small small amount of rub.
Old Nov 21, 2007 | 09:05 AM
spudsterier
with 205/40-17's ive never had any rub at all......even with 215/40-17's i didnt have any
the white r/t is running 205/55-15's and no rubbing and the speedo is just about right on
Old Nov 21, 2007 | 04:14 PM
tattoojack's Avatar
tattoojack
yeah spud, i dont think tires/rims that would make the speedo noticabley "off" would even fit under our fenders and rub like hell!
Old Nov 21, 2007 | 04:44 PM
spudsterier
195/75-14's throw it off a bit
