Is my CAI installed correctly?
Old Nov 22, 2007 | 02:22 PM
spudsterier's Avatar
spudsterier
Default RE: Is my CAI installed correctly?
ORIGINAL: justinsanders
flip the main pipe around and reconnect the other pipe and filter. then that bracket should be obvious to where it mounts.
that what i was gonna say.....looks like that bracket is supposed to mount to the bolt that hel the stock breather box to the head
Old Nov 22, 2007 | 07:20 PM
tattoojack's Avatar
tattoojack
exactly! look how the pipe makes almost a 180 where the filter is. its on backwards. that 180 is supposed to come out the TB and down under the battery box.
and neonracer, who the hell do you think you are?
Old Nov 22, 2007 | 07:35 PM
Aerorat's Avatar
Aerorat
ORIGINAL: tattoojack
Under the battery????? when or if he spends the main pipe around it will only make donw beside the valve cover.
Old Nov 22, 2007 | 08:58 PM
spudsterier
i could see how it would go under the battery box, but i just think the long pipe is backwards.....swap 12 o'clock to 6 o'clock, then put the short piece back on at the new bent location.....it would basically put the end of the filter right up against then power steering resivor
Old Nov 22, 2007 | 09:17 PM
justinsanders's Avatar
justinsanders
problem solved...
