i wanna turbo!!
Old Nov 22, 2007 | 09:26 PM
99r/tneon's Avatar
99r/tneon
Default RE: i wanna turbo!!
cool. yeah i know, i have the boost controller and a blow off already.. i was thiknin (since the internals are all stock) about runnin like 7 or 8 psi. how big of a difference ya think it would make?
Old Nov 22, 2007 | 09:37 PM
Slashwannabe's Avatar
Slashwannabe
I'm running the Mitsubishi TE04 Turbo and it is quite a thrill! spools quick and never quits! as soon as you hit the kick down its ready to go! I can churp my tires into second gear with my automatic!.
Old Nov 22, 2007 | 10:00 PM
spudsterier's Avatar
spudsterier
7-8psi is very noticable....i am running 8psi with my stock motor and runs fast as hell.....on the built motor i was running 15psi and that was extremely noticable
Old Nov 22, 2007 | 10:04 PM
99 Neon's Avatar
99 Neon
yeah play it safe and run 8psi you dont wanna mess up your motor
Old Nov 22, 2007 | 10:18 PM
95to96transplantneon's Avatar
not to bring you down 99rtneon but that turbo is internally wastegateed at 7-8 psi anyways the boost controller is not going to help. you will not be able to go above that. And since your aiming for 8 psi anyways just leave it be and dont waste your money on a boost controler or even set it up. just more lines that can get a rip or cut in them ending in bad things happening.
Old Nov 22, 2007 | 11:51 PM
99r/tneon's Avatar
99r/tneon
alright, dont worry man your not bringin me down, i love havin all this help! i had the boost controller and blow off from my old car.. so this might be a stupid question but what all will i need for this job?? i am not to informed woth turbos (really want to learn though)
Old Nov 23, 2007 | 12:03 AM
heres spuds list of things....its for the srt turbo and manifold so i edited it for your set up...and theres alot of things on this list you dont NEED but if you want to do it right heres the list...Slash just threw on a turbo and manifold and said here we go but not recomeneded he has an extra motor just wants to see what the block can take...
your turbo
a turbo manifold that is flanged for your turbo
intercooler
downpipe/cat. convertor
oil/coolant lines
blow off valve
walbro 255 lph external fuel pump
2.5" aluminum intercooler pipe kit
aeromotive fuel pressure regulator
map clamp
fuel return line
misc. vaccum lines
misc. fittings
oil ending unit T fitting
3 gauge piller pod....dont need 3, but i like gauges
srt boost gauge
electric oil pressure gauge.....
air/fuel gauge
Old Nov 23, 2007 | 12:13 AM
99r/tneon's Avatar
99r/tneon
alright well i have the blow off valve, a two gauge piller pod, srt-4 boost gauge,i jus put a new timing belt,water pump,and cluthcon my car. so i am donin pretty well so far! haha i cant wait for this! lol oh and i also have an extra engine,two transmission, and an extra head.
Old Nov 23, 2007 | 12:20 AM
spudsterier
i edited that list above to show basically what you need for any turbo
