2 year Turbo plan.
Old 07-10-2008, 11:42 PM
Durnald_Toad's Avatar
Durnald_Toad
Durnald_Toad is offline
Default RE: 2 year Turbo plan.
I was going to go turbo when I started this post but scents then I blew my motor up.
I decided to just get a cam and stronger bottom end in my good motor out of my parts car.
As we all know HorsePower is addictive so maybe a turbo will be in the future. Then, I will have to change out stuff again like the pistons.
Right now, this is about all I can afford to do.
Captansavaho, what under your hood ?
Old 07-10-2008, 11:43 PM
Captansavaho's Avatar
Captansavaho
Captansavaho is offline
nothing really haha
Old 07-11-2008, 12:26 AM
I_Ride_Neon's Avatar
I_Ride_Neon
I_Ride_Neon is offline
lol, a drawing of a engine on a piece of cardboard.
Old 07-11-2008, 12:46 AM
Durnald_Toad
I_Ride_Neon,
What all did internal did you do ?
How long have you had the turbo going and hows your motor doing ? leaks or anything ?
Old 07-11-2008, 01:01 AM
Durnald_Toad
Ok, wow. I just looked threw your links I_Ride_Neon!
Old 07-11-2008, 01:06 AM
Durnald_Toad
Do you still have the dash clusters ?
Old 07-11-2008, 01:12 AM
I_Ride_Neon
Oops sorry. Hehe you like my setup eh? I was running 10 psi for 2 months then I ran 12 psi and it made 2 pass's and cracked a piston. Then made 2 more pass's and was still driving! But yea it was fun. Then I rebuilt it high compression all motor sohc. Then blew it up because rev limiter ****ed up. Now I am building a stock sohc lower end with dohc top end and srt turbo. On my driveway. I still have the gauges clusters yes. I have a for sale post go look at it.
Old 07-11-2008, 01:16 AM
I_Ride_Neon
Want to know how much this build will cost me.
sohc lower end low miles= 150
dohc head=70
dohc ecu=20
sensors and wires for harness=40
Walboro=50
srt-4 turbo=220
gauges and hoses=120
rrfpr=130
exhaust=50
Gaskes and belts 120
Thats about it. that involves a turbo build and a dohc swap with a low mileage lower end. That willl lower the compression also. I plan to run megasquirt on it with 5psi. See what happens. I doubt I can do ms. I am novice with cars.
Old 07-21-2008, 03:45 AM
Durnald_Toad
Not bad at all.
I got the bottom end rebuild w/ 10.5:1 pistons and #14 Crane cam with springs. This should run well untill I switch out the pistons and throw on a turbo.
Man! This is takeing alot of time and money...
Quick Reply: 2 year Turbo plan.
