98 Neon Back-up Lights not coming on
Old Nov 27, 2007 | 10:57 AM
foundwaves's Avatar
foundwaves
Default 98 Neon Back-up Lights not coming on
I have a '98 Neon and all of a sudden one day the reverse lights stopped working. The weird thing is that when you put the shifter between Reverse and Neutral the lights come on then. I wasn't sure if it is a netural saftey switch or a back-up light switch or if it is something completely differtent? If someone could help me out on what needs to be fixed and how to fix it I would appreciate it a lot.
Old Nov 27, 2007 | 11:27 AM
pimpberetta's Avatar
pimpberetta
Default RE: 98 Neon Back-up Lights not coming on
I don't know if my problem is similar, but my back up lights didn't work since i bought my car, they seemed to work when i had some pressure on the gear shifter in reverse, not sure whether it was forward or backwards I was applying the pressure, but it would sometimes turn the lights on.
When I did the atx to mtx swap, I found the battery tray was broken and sitting on the shifter cables causing them not to sit right. Problem solved, maybe you're cables are outof alignment?
(now I have the mtx and my backups don't work at all?!) Too lazy to check the switch lol
Good luck
Old Nov 27, 2007 | 06:16 PM
99 Neon's Avatar
99 Neon
ha mine dont work either. Think its the cables as they are loose. havent checked it out i just hit the brakes a lot when i reverse at night to see whats behind me
Old Nov 28, 2007 | 08:42 AM
hatchetman2590's Avatar
hatchetman2590
instead of putting preassure i just keep going from nuetral to reverse real fast till they turn on lol if that dont work keep hitting bakes
Old Nov 28, 2007 | 10:29 PM
spp's Avatar
spp
ok my problem is different this my second tranny and my reverse light don't work either. on my first tranny they worked any ideas of wat it is
[/align]
Old Jan 20, 2013 | 11:27 AM
civichater83's Avatar
civichater83
Anybody figure out this problem? Im having the exact same problem I have to hold the shifter between reverse and neutral.
