i think i have a transmission problem
Old Nov 27, 2007 | 04:08 PM
snunicycler's Avatar
snunicycler
Default i think i have a transmission problem
my 96 automatic neon has had this problem for a while and to fix it, i add transmission fluid... but then i have to add more in like a month or so. usually it happens when i come to a stop, once i accelerate, the engine revs like it is in neutral and then all of a sudden goes into drive and i lurch forward. does anyone know what it could be? i have done some repair work on the car and i have a repair manual. is this something that is an easy fix or should i let a mechanic do it?
Old Nov 27, 2007 | 04:28 PM
spudsterier's Avatar
spudsterier
Default RE: i think i have a transmission problem
your probally leaking fluid out of the tranny pan gasket.....my wifes car has this problem, i just dont care enough to fix itbut it only leaks a little, you can se a few small spots in the driveway but it isnt much
Old Nov 28, 2007 | 08:22 AM
das2123's Avatar
das2123
If your level is good and you still have that problem, you could try a fluid and filter change along with adjusting the kickdown band. If that doesn't help, you may need a new tranny.
