Little trouble with my push button start
Old Dec 1, 2007 | 12:17 PM
99 Neon's Avatar
99 Neon
Default Little trouble with my push button start
So for the passed couple days when i have some free time and its not dark out i have been tryinh to get my push button start to work. With the DIY version ziggyneon made his only had 2 wiring terminals to hook up heres where my problem comes in....i have for. Im not the best at figuring out wiring, but if someone tells me how to do it i can do it. I have 2 spots mid way through the push button and 2 on the bottom. The place gave me a crappy installation guide (and by installation guide i mean 4x6 piece paper thats a wiring diagram.) Well its not the best diagram. Basically what it says is 1 wire is grounded. 1 is spliced into another wire which runs to the + part of the battery and the last wire goes to the word start on the diagram. Now i know the yellow wire is the ignition to run a wire there and the blue is like the a/c but it recongnizes that the car is on or something. Ill get some pics up when im home later and be any more descriptive and accurate cause i might be a little off right now. But if you can help me out thanks if not and i cant get this going in the next few days.....anyone intrested in buying a push button start?
Old Dec 1, 2007 | 04:33 PM
jfink's Avatar
jfink
Default RE: Little trouble with my push button start
so far from what i read you need to hook the ground to something metal(find a bolt or screw that connects to something metal), hook the positive wire to the red wire going into the wire harness for the igntion switch and the ignition wire into (what might be a yellow wire) if you have a test probe just ground it and probe the wires until you find the wire that lights up only when the key is in the crank only position it is in the same wiring harness for the ignition. that should be it, but you mentioned another wire for that i don't know. don't know if this will help but it is something to go off of.
Old Dec 1, 2007 | 05:49 PM
99 Neon's Avatar
99 Neon
really? the red wire. I know one needs to be in the ignition yellow wire and supposedly the blue wire is what recongnizes the car is on the on postiion so one goes in there too.
Old Dec 1, 2007 | 09:06 PM
jfink's Avatar
jfink
the push button switch needs a "hot wire" going into it, then from the switch it connects to the ignition wire(possibly yellow could be wrong). then to make it all work just ground it. has for the acc. wire...couldn't tell ya. could try calling the manufacturer of the switch and see what they say?? might be easy for them to translate the instructions for proper installation
Old Dec 2, 2007 | 12:27 AM
95to96transplantneon's Avatar
this may help...
https://dodgeforum.com/m_576573/tm.htm
Old Dec 2, 2007 | 02:11 AM
12 volt's Avatar
12 volt
ORIGINAL: 95to96transplantneon
this may help...
good find
Old Dec 2, 2007 | 11:58 AM
boxerjl2's Avatar
boxerjl2
GREAT FIND BUT...
So for the passed couple days when i have some free time and its not dark out i have been tryinh to get my push button start to work. With the DIY versionziggyneon made his only had 2 wiring terminals to hook up heres where my problem comes in....i have for. Im not the best at figuring out wiring, but if someone tells me how to do it i can do it. I have 2 spots mid way through the push button and 2 on the bottom. The place gave me a crappy installation guide (and by installation guide i mean 4x6 piece paper thats a wiring diagram.) Well its not the best diagram. Basically what it says is 1 wire is grounded. 1 is spliced into another wire which runs to the + part of the battery and the last wire goes to the word start on the diagram. Now i know the yellow wire is the ignition to run a wire there and the blue is like the a/c but it recongnizes that the car is on or something. Ill get some pics up when im home later and be any more descriptive and accurate cause i might be a little off right now. But if you can help me out thanks if not and i cant get this going in the next few days.....anyone intrested in buying a push button start?
Old Dec 2, 2007 | 01:59 PM
99 Neon's Avatar
99 Neon
thank you boxer ill put up more info when i actually get home been gone all weekend. Get some pics up and everything so i dont waste more time on this project
Old Dec 3, 2007 | 03:27 AM
boxerjl2's Avatar
boxerjl2
kk cant wait to see
Old Dec 4, 2007 | 01:11 AM
99 Neon's Avatar
99 Neon
I scanned in the "detailed instructions" on how to install my push button start the hand writing that says yellow, blue a/c is me guessing where it goes dont pay any attention to that. So with this now can anyone tell me where each wire goes......
