Got a question about my 1997 Neon DOHC......
Old Dec 2, 2007 | 12:38 AM
1997_neon's Avatar
1997_neon
Default Got a question about my 1997 Neon DOHC......
Ok. My car ... 1997 Dodge Neon DOHC and my Service engine soon light was on well then my car wouldnt stay running... So my brother works on cars and he said the EGR valve so we bought a Used one and put it on and that didnt help.......you turn the key and it will not stay running.........any other tips besides a EGR valve..........when i replaced that the service engine soon light went out but it still runs like poop. Can any1 help?
Old Dec 2, 2007 | 01:06 AM
95to96transplantneon's Avatar
Default RE: Got a question about my 1997 Neon DOHC......
Ok run out to your car and put your key in now there are three positons you can turn your key to off on and start keep that in mind.... now take your key that is now in the off postion and do this withing 5 seconds. On - Off - On - Off - On. The check engine light will begin to flash like morris code. Depending on how many times it flashes it will corispond with a diagnostic code that we will be able to decode.
Like if it flashes blink-blink-blink-pause-blink-blink-blink-blink this will be code 34 meaning Speed Control Solenoid Circuit is bad. there may be more then one code so stay alert. you will always get code 55 it means end of codes.
Go do that and tell us what you get...
Old Dec 2, 2007 | 12:02 PM
1997_neon's Avatar
1997_neon
Hey i tried that and it didint blink...........my dad wants to know if maybe the fuel filter is bad or if it even has 1............thanks for the reply.....[sm=thanx.gif]
Old Dec 2, 2007 | 12:10 PM
spp's Avatar
spp
i had the same problem check ur feul relay play wit it r change it that might help
[/align]
Old Dec 2, 2007 | 01:35 PM
1997_neon's Avatar
1997_neon
Ok thank you for the reply.........could you tell us here that is located......We are no auto machanics. [sm=bangbang.gif]lol
Old Dec 2, 2007 | 01:44 PM
12 volt's Avatar
12 volt
ORIGINAL: 1997_neon
its is located under your hood in the fuse/relay box. if i remember correctly ist the one thats is closer to the grill
Old Dec 2, 2007 | 02:21 PM
1997_neon's Avatar
1997_neon
Ok i pulled 1 out for the fuel pump but im thinking about going and buying a new 1 ...... Thanks
