will a 2nd gen motor fit in my first gen
im figureing that i can buy a new engine for about as much as it would cost to get mine fixed so what you think will it fit
sorry i did not search i have to go to work
again sorry
again sorry
really
... yeah i really dont have time for that ive heard the srt4 swap is a pain in the a$$ and would rather not go through that.. i just found a cheap 2.0 engine for a 2003 (and it has low miles) so I was wondering if it would fit but i guess ill stick with the 95-98 motor if i can find a good deal
you could just do then/a2.4 swap
...but stick with 95-99 engines(2.0 or 2.4) for the fact 2000+enginesyou would need to do almostasmuch stuff as the srt-4 swap.
^^^Not quite as much as the SRT-4 swap, but some work would need to be done. Boxer, keep in mind that the 03 engine will not have an EGR port, so will would have to drill and open it up if you wanted to keep the EGR system.
the ecu (pcm) would not work and i think it has a different...well a lot of things are different
Trending Topics
nope need an adapter on the passenger side.... heres a link...
http://www.modernperformance.com/pro...25505edca976b3
theres a few other things that you need to do like switch some wires around on your ecu. and modify your front motor mount. and use a different alternator bracket... just to think of a few things but its all easy stuff...even you can do it boxer... lol jk
