timing belt broke wat u think happened to the valves
Old Dec 5, 2007 | 12:40 PM
spp's Avatar
spp
Default timing belt broke wat u think happened to the valves
haha mani think is time to go dohc watch out honda people im coming again
[/align]
Old Dec 5, 2007 | 09:01 PM
mr340's Avatar
mr340
Muscle Car Moderator
Default RE: timing belt broke wat u think happened to the valves
ORIGINAL: spp
So you can bend twice as many valves???
Old Dec 5, 2007 | 10:05 PM
95to96transplantneon's Avatar
um....SOHC and DOHC have the same amount of valves.
Old Dec 6, 2007 | 01:03 AM
pimpberetta's Avatar
pimpberetta
lmao wow..
On a serious note, i've scene a 2000 integra blow 2 timing belts and still has the original valves. It too has the interference design.
You really have to pull the head to find out if there broken. Its a pretty simple job, I'd say tear it apart first.
Old Dec 6, 2007 | 06:15 AM
mr340's Avatar
mr340
ORIGINAL: 95to96transplantneon
[sm=sigh.gif]It just ain't funny if you have to explain the joke...
Old Dec 6, 2007 | 01:30 PM
das2123's Avatar
das2123
ORIGINAL: mr340
I don't get it [&:]
Old Dec 6, 2007 | 02:43 PM
12 volt's Avatar
12 volt
you cando a compression testto findout if they are bent without removing the head. while your doing the test put your ear on the intake TB and see it you hear the air moving past the intakevalves.
Old Dec 6, 2007 | 03:30 PM
Jr. Mechanic's Avatar
Jr. Mechanic
A leak down test is more effective, but if you are going to tear it down anyways, its not worth the time...
Old Dec 6, 2007 | 09:09 PM
mr340's Avatar
mr340
ORIGINAL: das2123
ORIGINAL: mr340
I don't get it [&:]
Based on the following statement, it would appear that the car is going to get twice the beating it has already taken.
ORIGINAL: spp
