drive axles
Old Dec 11, 2007 | 12:30 PM
neoncrazy101's Avatar
neoncrazy101
Default drive axles
i cant get them out. i was out there for like an half an hour trying to get the passenger side one out and it wont bloody come off. so how in the world do u get it off? i took the axles out of my other Neon with no problem but with this Neon its being a PITA
Old Dec 11, 2007 | 01:56 PM
das2123's Avatar
das2123
Default RE: drive axles
Did you twist and pull?
Old Dec 11, 2007 | 02:06 PM
neoncrazy101
i was told not to pull on the axle cause it could mess up the axles.
Old Dec 11, 2007 | 02:09 PM
das2123's Avatar
das2123
Uh.....thats how I get them out.
Old Dec 11, 2007 | 02:16 PM
neoncrazy101
i'll try that then...
Old Dec 11, 2007 | 02:44 PM
tranyinstaller's Avatar
tranyinstaller
if u pull on the axles you will seperate the knuckle inside the boot. so long as the boot doesnt come off ur ok. i usually use a pry bar between the trans and axle hub. im assuming ur havingt a problem getting them out of the trans. also when u use the pry bar rotate the axle so ur not always pry at the same spot. just use good common sence when u do it. u dont wanna brake anything
Old Dec 11, 2007 | 09:59 PM
neoncrazy101
pulling on it we broke it lol. so i'm just gonna put the axles from my green Neon in on re-install. new question, how in the world do u get the transmission out??? my 95 green Neon was so easy. this one is being a butt. do i take off the flywheel while the transmission is in or when its out? i think thats our big problem. cause it has the module clutch whereas the 95 was the conventional.
Old Dec 12, 2007 | 12:20 AM
pimpberetta's Avatar
pimpberetta
The flywheel is bolted to the crankshaft, so you will have to remove the transmission first to get the flywheel off.
