Question about codes
Old Dec 13, 2007 | 07:59 AM
stodd4's Avatar
stodd4
Default Question about codes
One of my Neons (96 Highline)has thrown me some codes. 32, 37, and 21.
21 - 02s sensor problem (oxygen sensor), upstream or down stream
32 - EGR system failure
37 - Torque converter clutch solenoid CKT or park/neutral switch failure
My questions are:
How do you tell, (if you can) which O2 sensor is bad. And.......How do you tellwhich of thethe torque converter clutch solenoid or the neutral switch failed. And could the EGR system failure code be from theO2 sensor problem? I am pretty sure one of the O2 sensors is bad because I can smell gas and the carskeeps trying to die.
Old Dec 13, 2007 | 05:26 PM
95to96transplantneon's Avatar
Default RE: Question about codes
I would just swap out the o2 sensor there only like 20 bucks on ebay.
Old Dec 13, 2007 | 07:58 PM
moparman73's Avatar
moparman73
i would get an OBD2 code reader and that will narrow down ur codes alot.
Old Dec 13, 2007 | 10:02 PM
stodd4's Avatar
stodd4
Ok.......thanks for the responses. I have decided to just change everything. It doesn't cost that much and it will provide piece of mind.
Old Dec 14, 2007 | 08:35 AM
das2123's Avatar
das2123
Most likely it's your upstream O2 sensor.
Old Dec 14, 2007 | 10:06 AM
hnda8r's Avatar
hnda8r
Its most likely the uspstream, but you can go to an autozone or advance and they can tell you right away.
