One last thing before i start. i have everything i need but a rrfpr. I have 2 fpr's. Is there anyway to get around not using the rrfpr because my budget is getting low and i want to hold onto some money so if i get in there and find anything wronge i can fix it. Any input would be great. Thanks.
The problem would be that your stock fpr would still regulate the pressure at 49 pounds, wouldent be able to go any higher.....unless you did the spoolboy???
acually after thinking about it. you should be able to run low boost with that regular fuel pressure regulator. just set it for about 55psi and about 5lbs of boost. and then adjust your map clamp screw so you get an exeptable a/f ratio. If you go any higher boost wise you will lean the car out bad.
