Vacuum
Old Dec 20, 2007 | 09:14 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Default Vacuum
Okay so one last question on this. Turbo project. Can i just use the vaccum hose off the intake manifold that is between 3 and 4? Because mine doesnt have the bolt between 2 and 3. The prblem is that is is used to suck on the valve gasket cover. Can I "T" of that. The valve cover gasket doesnt need that much vacuum does it? All i am running is 2 fpr's, blow-off, and boost guage. Then the wastegate on the turbo also goes off of it. Will that hurt anything or do anything bad?
Old Dec 20, 2007 | 09:25 PM
95to96transplantneon's Avatar
Default RE: Vacuum
your talking about what i have in the picture circled in circle one, right???(click on pic to see red circle)
thats your pvc valve. I wouldent go off of that since the motor does use it for a productive purpose.
you seriously dont have the bolt that is circled in circle two???
[IMG]local://upfiles/61619/3F6B509240294F3CB49FD700A811F1F9.jpg[/IMG]
Old Dec 20, 2007 | 09:56 PM
I_Ride_Neon
Default RE: Vacuum
Promise i dont. It has the flat spot of where its suppost to be. Maybe someone got lazy at the dodge factory. HAHA. I have a 95 manifold that does but the egr is set of deifferent on it. Well i broke the pcv hose today anyways ripping everything off.
Old Dec 20, 2007 | 10:04 PM
Default RE: Vacuum
Well then...lol
Just plug the damn egr off and switch intakes the egr just dirty's up the intake manifold anyways. I looked down my tb the other day and I almost threw up...(god whats going to happen when i have kids)
Well its an easy fix. then you dont have to splice anything.
Old Dec 20, 2007 | 10:26 PM
I_Ride_Neon
Default RE: Vacuum
Well i just got a new egr, i kinda like the idea of emissions :-). It was like $80.
Old Dec 20, 2007 | 10:29 PM
Default RE: Vacuum
EGR block off = 15 bucks
look on wifes face when I spend 80 dollars = pissed. lol
Old Dec 20, 2007 | 11:59 PM
I_Ride_Neon
Default RE: Vacuum
15 where? will that throw off a code?
Old Dec 21, 2007 | 12:46 AM
spudsterier's Avatar
spudsterier
Default RE: Vacuum
blocking the EGR will throw a code......i made my old block off plate for about $3
Old Dec 21, 2007 | 01:00 AM
Default RE: Vacuum
Sorry 20 with shipping.
http://cgi.ebay.com/ebaymotors/EGR-B...mZ350007737558
Old Dec 21, 2007 | 06:38 PM
I_Ride_Neon
Default RE: Vacuum
I ended up drlling and threading the 96 one. Thanks alot for the help.
