water pump leaking???
Old Dec 23, 2007 | 11:07 PM
neoncrazy101's Avatar
neoncrazy101
Default water pump leaking???
my car is leaking antifreeze and i finally figured out where it was coming from... (see photo)
(thats from my other Neon but its the same location.) its where it splits into two lines with one going to the heater and the other to the radiator/motor. would that be my water pump??? or just that peice is loosing its grip or whatever?
Old Dec 23, 2007 | 11:36 PM
Slashwannabe's Avatar
Slashwannabe
Default RE: water pump leaking???
Could possibly be your water pump bearing, when mine leaked from the same place it was the bearing that went out and leaked out anti freeze all over the front of my engine even in the same place your picture is taken. It wasn't leaking from that side but from from wind and what not it got thrown to that side and once I put a new water pump in no leaks or wetness from that side at all.
Old Dec 23, 2007 | 11:41 PM
neoncrazy101
ok cause about 4k ago i replaced the water pump. so i wasn't sure.
Old Dec 24, 2007 | 01:18 AM
spudsterier's Avatar
spudsterier
if its leaking from right there, then i would assume that you just need a new o-ring for where the plastic tube goes into the block...
Old Dec 24, 2007 | 10:10 AM
neoncrazy101
know what the parts name is? lol besides the o-ring?
edit: I just went and moved the car out of my garage and.....there was chocolate milk under the car. went to check the oil and oil was all gone and the coolant was all gone. it never lost oil before so it kinda sounds like the head gasket. bloody dang it and i checked the front and sides of the head and theres no leakage but on the back its nothing but oil on the backside of the motor and head
Old Dec 24, 2007 | 01:14 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Didnt you just do the head gasket?
Old Dec 24, 2007 | 02:07 PM
neoncrazy101
ORIGINAL: Jr. Mechanic
yeah i did...and the water pump. both at the same time 4,000 miles ago. and i did just replace the rear main seal. and i know for sure i did it correctly cause it lined up flush with everything just like the book saids too. so. i dont know anymore. theres a Neon down the street from me for sale. its a DOHC auto though but we're see.
Old Dec 24, 2007 | 05:54 PM
spudsterier
as far as i know, the o-ring is just considered a water pump gasket....you just have to specify if its the gasket or the o-ring
Old Dec 24, 2007 | 06:03 PM
Slashwannabe
ORIGINAL: spudsterier
I don't think it would be called the water pump gasket as it doesn't touch the water pump directly and theres allready a o ring gasket that directly touches the water pump.
Old Dec 25, 2007 | 12:26 AM
spudsterier
ORIGINAL: Slashwannabe
ok...ok...
its the bottom one
http://www.autozone.com/N,16300415//...eResultSet.htm
