pcm part numbers
ok i know that the mopar performance part numbers are as follows
Check the part#. See the Mopar part #s below...
P5007033 PCM[/b] (1995 Neon SOHC)
P5007034 PCM[/b] (1995 Neon DOHC)
P5007035 PCM[/b] (1996 Neon SOHC)
P5007036 PCM[/b] (1996 Neon DOHC)
P5007037 PCM[/b] (1997–99 Neon SOHC)
P5007038 PCM[/b] (1997–99 Neon DOHC)
however what are the stock part numbers???
A guy on EBAY says these #s will work on a NEON 95 Elec Cont Unit (ECU); SOHC, MT, Fed and Canada.... Does anyone have one of these? and does thid sound right?
Ident: 4874154
Ident: 5269602
Ident: 5269646
Ident: 5269709
Ident: 5293086
Ident: 5293119
Ident: 5293123
Ident: 5293381
Ident: 5293461
Ident: 4874154
Ident: 5269602
Ident: 5269646
Ident: 5269709
Ident: 5293086
Ident: 5293119
Ident: 5293123
Ident: 5293381
Ident: 5293461
heres the deal my p/n is p05269939 need to know what it is...since im unsure what the previous ownerused for my swap.
