weekend rebuild through the oil pan??
Old Dec 27, 2007 | 02:30 AM
jimustanguitar's Avatar
jimustanguitar
Default weekend rebuild through the oil pan??
i've got a 96 with a 2.0... can the pistons be pulled out through the oil pan without removing the crank if i want to do new rings a rod bearings? i had a ford truck that i could rebuild in a weekend, i had to do it twice cuz i i plasti-guaged the bearings not knowing that they were already oversize, so the bearings that i put in were not the correct ones the first time. anyway, i was just curious, thanks.
Old Dec 27, 2007 | 10:08 AM
spudsterier's Avatar
spudsterier
Default RE: weekend rebuild through the oil pan??
you cannot get the pistons out through the bottom without removing the crank....you have to go through the top
