Old Aug 6, 2015, 01:31 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting
Print Wikipost
Reverse Lights! Help!!
Old Dec 3, 2004 | 06:37 PM
xprettylilmommyx's Avatar
xprettylilmommyx
Default Reverse Lights! Help!!
I have a 95' Dodge Neon. It is an automatic. My reverse lights don't work. I went to Oreilleys last night, the bulbs were good they tried new ones anyways still did not work, fuses were also good. They gave a Safety Neutral switch, and told me it goes on the transmission on the backside under the hood. Does anyone know where this would be? Also what else it might be if it is not the Neutral Safety Switch?
Monica,
Old Dec 3, 2004 | 06:45 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default RE: Reverse Lights! Help!!
yes it should be..if is not the fuses, or bulbs, it has to be the NSS, or somethign could be misaligned in the shifter itself..but thats not very likely. however, if it wa a bad NSS, you would begin have problems starting it. see if you can start it in neutral.
Old Dec 3, 2004 | 06:55 PM
xprettylilmommyx
ok thanks, where would i install it do you know? they said on the transmission...but where?
Old Dec 3, 2004 | 06:56 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
hmmm...i dont have an manual handy..and i dont own a neon...im sorry...
Old Dec 4, 2004 | 03:42 AM
ewetho's Avatar
ewetho
Also try a test light and multi-meter.
This would let you know that you have voltage & ground to the socket when you should. If no ground is available or no power then of course no light. If you find voltage with a multi-meter and verify ground then use a test light and see if it lights when probing power side where voltage was found. If it does not than the problem would be resistance in the wiring. This is an important step because if your wiring is bad that no amount of control parts will fix. Must fix wires.
Also you can check your power to your Fuse Socket the same way. With the car in reverse you should get continuity to ground in socket on outlet of fuse.
Then check down at intervening circuit parts such as switches, etc...
Old Dec 6, 2004 | 01:26 AM
TJW815's Avatar
TJW815
reverse lights?? well I haven't been able to tell if mine worked since i tinted my windows this past spring, I just back up till I hear a cruning noise J/K...
Old Oct 11, 2006 | 12:29 AM
bishop's Avatar
bishop
aha :P yeah same here
