oil light on
Old Jan 2, 2008 | 06:09 PM
lateralus823's Avatar
lateralus823
Default oil light on
Cars having some problems, just replaced the egr valve and the 02 sensor and now my oil light is on but it goes off when i am on the gas, it also idles odd and stumbles kinda any ideas?
Old Jan 2, 2008 | 06:33 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Default RE: oil light on
Did you check your oil levels?
Old Jan 2, 2008 | 06:42 PM
lateralus823
Yeah i just got it changed, albeit at walmart, it was changed like 2 days ago. But its so weird, it comes on at idle, when im accelerating it stops.
Old Jan 2, 2008 | 06:49 PM
spudsterier's Avatar
spudsterier
might be a bad oil sending unit....
Old Jan 2, 2008 | 08:24 PM
lateralus823
How much and how hard are they to install?
Old Jan 2, 2008 | 08:44 PM
Jr. Mechanic
But did you personally check it? When you accelerate the oil will slosh to the back of the pan where the sensor is.
Old Jan 3, 2008 | 05:46 AM
lateralus823
spud how hard are they to change.?
Old Jan 3, 2008 | 09:10 AM
das2123's Avatar
das2123
ORIGINAL: lateralus823
Not hard at all. Inspect the wiring to the sending unit as well.
Old Jan 3, 2008 | 07:42 PM
lateralus823
Where abouts is it located das? I got under ym car and i saw a sensor located near a boot type thingy would that be it? its right near the bottom of the car?
Old Jan 3, 2008 | 11:01 PM
Slashwannabe's Avatar
Slashwannabe
Its the Oil Pressure sensor on the left side of the pic.
