99 dodge neon shuts off
Old Jan 8, 2008 | 04:51 AM
95to96transplantneon's Avatar
Default RE: 99 dodge neon shuts off
Is your check engine light coming on at all???
If so do the key dance (off on off on off on) no start just off on and count the blinks theres a sticky that tells you how to do it...
if no, I would do this....
check your aternator wires mainly the one that runs from your battery to your alternator. Second check the battery to starter wire.
then check the ground from the starter to the front radiator support...
Then check the battery to fuse relay box...
After that I dont know... Neons are so picky about there grounds and power supplys its not funny...
Try changing out your battery to alternator wire.... Honestly If its not one of those things I would be supprised...
Old Jan 8, 2008 | 06:52 AM
purecty's Avatar
purecty
no, the engine light doesnt come on when it does this.. i will check all grounds as soon as im able, ty kindly
bill
Old Jan 8, 2008 | 02:12 PM
I was mostly talking about the power wires to your alternator starter and relay box...
Old Jan 8, 2008 | 06:24 PM
purecty's Avatar
purecty
ok, ty kindly
bill
Old Jan 10, 2008 | 06:28 PM
purecty's Avatar
purecty
will the crank position sensor cause it to shut down like it does? i have a chance to get one this week. ty kindly
bill
