arggggghhhhhhhh F@!k
Old Jan 5, 2008 | 04:34 PM
jfink's Avatar
jfink
Default arggggghhhhhhhh F@!k
[:@]damn it i fix one problem and two more arise. i'm pissed. the other day i was driving and all of a sudden there is a noise like there is something rubbing with one of the rear tires so yesterday i check it out and one of the springs in the driver side drum came off. so today i fix that and replace all the hardware in both drum brakes; while in the process of doing that i noticed that both madter cylinders are leaking(problem number one[:@]) so i blow it off and tell myself to calm down tomorrow i'll buy two new ones were i work and fix it tomorrow. so i get the brakes done and start cleaning up the mess when i notice a wet spot coming from the front going out past my passenger side tire "oh F!@k" sure enough i now have a coolant leak i have to find(problem number two[:@][:@]). Think it might be the radiator because the wet spots start from the front passenger side right next to the radiator and goes out to, what i can only call a black canister, all the way back to the floor pans. just thought i'd share my frustations to what was supposed to be a nice relaxing day.[sm=headbang.gif]
Old Jan 5, 2008 | 04:42 PM
12 volt's Avatar
12 volt
Default RE: arggggghhhhhhhh F@!k
damn............be careful you dont what to end up on the highway with no brakes and overheating.
i feel your pain
Old Jan 6, 2008 | 07:36 AM
Slashwannabe's Avatar
Slashwannabe
Same thing just happened to me except my break cylinders were stillgood but I had broken springs and worn shoes.
Old Jan 6, 2008 | 07:50 PM
jfink's Avatar
jfink
well i got a chance to look at my car to see exactly what is leaking and its the water pump(damn should have replaced it when i replaced the cylinder head[sm=headbang.gif]) but thankfully i went aheadand got a new one shortly after that; but now i gotta wait and get a new timingbelt and get my car back on the road tomorrow
