fuel injectors
Old Jan 7, 2008 | 07:25 PM
hatchetman2590's Avatar
hatchetman2590
Default fuel injectors
ok ihave stock f.i. so wat would be the best ones to have when i run a turbo? also by spring break im going to be drag racing 8 seconds ( my cars name, long story) at the local strip
Old Jan 7, 2008 | 08:24 PM
95to96transplantneon's Avatar
Default RE: fuel injectors
depends on how much boost your going to be running...figureing you do not have a built motor 24lbs'ers would work fine...hell the 19's that you have stock will work fine up to about 5psi.
Old Jan 7, 2008 | 08:29 PM
hatchetman2590
well by my 18th birthday (october) im going to be running 2 remote mounted turbos running about 20 lbs of boost so wat would be good ones to use for that setup?
Old Jan 7, 2008 | 08:49 PM
with a setup like that your going to need to use really big injectors its hard to say really...theres a calcuator on the web somewhere that you tell it what you have and it will give you a est. of what you are going to need. but its allway better to get bigger then you need and then turn the pressure down fuel psi wise... But honestly for something like that your going to have to find the calculator or talk to some of the 11 sec. neon guys...
I hope you have alot of money for the block though it's gonna cost ya...and to have that manifold made up is going to be expensive as hell to get it right...when you start doing things like duel turbo you need to have the primarys just right and you will probally have to use v-band turbos and have someone that knows what that means making your manifold...
Old Jan 8, 2008 | 12:17 AM
spudsterier's Avatar
spudsterier
stock injectors are good up to about 10psi....i usually ran 9psi with my turbo and stock injectors with no problems....
though i do have a set of hardely used accel 30# injectors for sale
