Headlight problem
Old Jan 8, 2008 | 01:04 AM
RedNBlack99's Avatar
RedNBlack99
Default Headlight problem
I'm having a problem with my headlights. When i turn the lights on, my right light wont turn on. I need to move a bit the cable connecting the bulb to make it work, I mean just move a bit the cable, so it works. Does anyone know what the problem is, or what can i do to fix it?
Old Jan 8, 2008 | 10:16 AM
spudsterier's Avatar
spudsterier
Default RE: Headlight problem
sumtimes theconnectors for the bulb start to wear out.....i had this problem a few times back in the day...
you can go to walmart and spend about $4 on a new headlight socket.....then just cut the old one off and wire in the new one
