fuel pump... still
Old Jan 15, 2008 | 07:09 AM
hatchetman2590's Avatar
hatchetman2590
Default fuel pump... still
ok all my fuses are fine, and i have replaced my fuel pump multiple times but it is not kicking in. it couldnt be a wiring problem cuz its not shorting out rite? also would it solve the problem if i got a in-line fuel pump instead?
Old Jan 15, 2008 | 08:24 AM
hatchetman2590
Default RE: fuel pump... still
one of my buddies said that it could be my ecu or pcm, wat ever u call it, could i just switch it out between my 2 neons?
Old Jan 15, 2008 | 11:48 AM
12 volt's Avatar
12 volt
ORIGINAL: hatchetman2590
have you checked the fuel pumprelay
Old Jan 15, 2008 | 03:19 PM
6sic6's Avatar
6sic6
or the asd relay?
Old Jan 15, 2008 | 06:15 PM
hatchetman2590
yes i have wats the asd relay
Old Jan 15, 2008 | 07:16 PM
6sic6's Avatar
6sic6
asd=Automatic Shutdown Relay.....
Old Jan 15, 2008 | 09:32 PM
hatchetman2590
i have heard about that also i know where it is in a crown vic. but not in the neon where is it?
Old Jan 15, 2008 | 09:40 PM
mr340's Avatar
mr340
Muscle Car Moderator
should be in the Power Distribution Center (PDC), fuse box under the hood by the battery.
Old Jan 16, 2008 | 07:04 AM
hatchetman2590
ok which relay is it though there is like 8 of them?
Old Jan 16, 2008 | 11:49 PM
pssssst's Avatar
pssssst
it should tell u right under the lid
