God this is so tempting...
Old Jan 19, 2008 | 02:32 AM
boxerjl2's Avatar
boxerjl2
Default RE: God this is so tempting...
i would still think that its got to do something... i mean not like a turbo but small amount of somehting...
idk but i have a fan that is shaped like a turbo that was use for keeping a fire going and i want to hook it up just for fun to see.. and im putting in a new engine anyways,,, but its got alot of pressure comeing out of it...
Old Jan 19, 2008 | 08:51 AM
bone33's Avatar
bone33
you can do this with a $12 hairdryer
Old Jan 19, 2008 | 10:52 AM
vlmuke's Avatar
vlmuke
I think I would spend the money on something else like headers on UD pulley
Old Jan 19, 2008 | 05:10 PM
I_Ride_Neon's Avatar
I_Ride_Neon
So my idea would be a leaf blower? Hook it into a power converter hooked to a turn **** switch to adjust the power to it. Huh? Huh?
Old Jan 19, 2008 | 05:35 PM
tranyinstaller's Avatar
tranyinstaller
in all simplicity consider this, seriously.
I myslef am not for the "electric turbo" concept, however if not to produce boost, think in terms of drag equivalency. if one atmosphere is 14.7 psi at sea level, then that is the pressure the atmosphere has to fill your cylender when its on the intake stroke. so if we run at -3 psi then we are only really at 11.x psi to push into a cylender. so if this electric fan were to reduce drag and equalize vacuum we could easily see 100 percent volumetric efficiency through the head. just by getting rid of -psi. we could demand less of the electric motor and keep it living instead of killing it for a short joy ride. reduce the voltage to it until your vacuum gage reads neutral.
perhaps not good enough to produce boost. but perhaps good enough to equalize vacuum? maybe.
tell me what you think.
Old Jan 19, 2008 | 06:12 PM
das2123's Avatar
das2123
ORIGINAL: 12 volt
maybe it would be a little more comforting if the engine was running.
50 hpfor $120 kinda seems like its too good to be true
Man don't be so negative....just think....$240 and you get an added 100HP
Twin supercharged neon!!!!!
*Disclaimer* the above statements were typed with sarcasm in mind!
Old Jan 19, 2008 | 08:01 PM
12 volt's Avatar
12 volt
ORIGINAL: I_Ride_Neon
this wont produce boost, blowers only increase the velocity of the air. You need a compressor to increase the pressure of the air
Old Jan 20, 2008 | 12:44 PM
vipersforsale's Avatar
vipersforsale
you have to compare the cfm that the electric fan produces anyway... most of these fans dont flow enough air to be useful even at idle. But the gas powered leaf-blower idea has been proven at the dyno... but who is going to run around with a leaf-blower sticking out of their hood? I have looked at the specs of some of the more expensive units and they can flow as much as 600 cfm or more
Old Jan 20, 2008 | 01:45 PM
boxerjl2's Avatar
boxerjl2
one of my civic friends was telling me about a mod he heard about were you take your ac vent and hook it up to your CAI... i cant really seeing this work but you guys always talk about trying to get the coldest air into your engine..
Old Jan 21, 2008 | 02:43 AM
boxerjl2's Avatar
boxerjl2
what you Think about that??? AC Cold air Flowing INto The CAI
