help srt4 swap
Old Jan 23, 2008 | 06:09 PM
spudsterier's Avatar
spudsterier
Default RE: help srt4 swap
ORIGINAL: andybos1991
im prety sure that going from a 3.2 to a 3.0 is somewhat like going from a 2.0 to a 2.4 only reverse
if you were goinf from a regular 2.0 to a regular 2.4 then it would basically be the same as the taurus.....but, since its an srt4 motor, there are a few differences with tis swap that need to be changed:
engine wiring harness
engine bay wiring harness
gauge cluster
ECU
motor mounts
front cross member
exhaust
intercooler
then you will also need to figure out how to change your setup from a cable clutch to a hydraulic clutch
not to mention tons of other stuff
did you check out the link i posted???
Old Jan 24, 2008 | 03:44 PM
andybos1991's Avatar
andybos1991
yea i checked it out well idc wat goes into it ive made up my mind that im going to do it and i know that if i cant do it i can get some help from people who can hopefully all goes well
