Supercharged ShowOff Whore.......:) 56kNO
Old Jan 23, 2008 | 07:02 AM
mmench's Avatar
mmench
Default RE: ShowOff *****.......:) 56kNO
hey wat part of PA are ya from? you should ride to the cecil county drag track sometime and race. would be cool if we could get a few turbo or nitrous 1G neons
Old Jan 23, 2008 | 07:16 AM
6sic6's Avatar
6sic6
^ Huntingdon
Heres a few more,
Intake and modern 60mm TB
The serpantine belt system, Had to use a diff crank puley with a 5 rib section and convert the power steering over
Mexican neon "half" rad
Relocated Tractor Battery,
Keizer 13lb 13"x8" drag wheels with M&H 22x8" slicks for the track
A fun Burnout,
http://s92.photobucket.com/albums/l3...t=MOV00549.flv
Old Jan 23, 2008 | 07:31 AM
DevilsReject's Avatar
DevilsReject
Noob Assassin
Those Eaton blowers are great...... very nice custom work....definitely need a video of it running
Old Jan 23, 2008 | 07:41 AM
thedaddy911's Avatar
thedaddy911
where can i get the custom mounting braces on the supercharger and the plate on the bottom of the supercharger.
Old Jan 23, 2008 | 08:32 AM
12 volt's Avatar
12 volt
its for the CryO2, ive got an rpm switch controlling it also
not trying to be an *** or anything but was just wondering if you have seen this site
http://www.cryofuzion.com/spraybar.htm
Old Jan 23, 2008 | 09:50 AM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
have u taken it to the track??? what was its time??
Old Jan 23, 2008 | 03:16 PM
6sic6's Avatar
6sic6
Waiting for spring^
ORIGINAL: 12 volt
Its not ****ing injected into the intake! and thers no way it would "Inevitably" get into the intake. It sprays over the Intercooler cooling it thus coling the air moving through it and the intake charge.
Simply rules of, cooler air is denser, more air, more power.
Now I wanna see that dufus prove it makes less power when its 100* outside, the Intercoolers heatsoaked like mad and the cryo2 drops you IATs about 30*, I GUIRANTEE it will help at the track heatsoaked at the tree.
Dont you think when he made the "10ft" intake extension he lost some power there to? He was also in a closed room and when a car is on the dyno it isnt in a slipstream of air carrying the extra co2 spray away from the car.
I wouldnt loose any sleep over that guys synopsis on that web page!!
Old Jan 23, 2008 | 03:32 PM
dtjackten's Avatar
dtjackten
^^ yeah, i had a co2 kit on my car, pulled it for a nitrous setup though...good luck and i would love to know what u run in the spring
Old Jan 23, 2008 | 03:36 PM
12 volt's Avatar
12 volt
ORIGINAL: 6sic6
Waiting for spring^
ORIGINAL: 12 volt
damn didnt think you would get so pissed over it but here goes my explanation. Cooler is a good thing agreed, so when your doing your run and your flying down the track you hit the CO2. The gas goes thru the intercooler filling the engine compartment with the gas and thus going into the intake filter.
what im trying to say is the cooler isnt a bad thing it just needs to be used before you do your run thats all. Most of the people that i know only use water forcooling the IC during there run, doesnt cool as well but its still something.
Old Jan 23, 2008 | 03:42 PM
6sic6's Avatar
6sic6
Tracks HIgHLY frown upon using water at the track for IC spraying, (puddles, no good for traction).
Actually I do mostly plan on using it when shes heatsoaked at the tree. And on the street in hot days.
Dude only lost 4hp. if that does happen, Id rather loose a litle power than risk high IaT's and detonation.
