i need help{shaving of a head}
Subscribe
Jan 29, 2008 | 01:28 PM
am i safe to take off 30 thousanths on a dohc head with out have valve clearance issues??
Reply 0
Jan 29, 2008 | 02:59 PM
RE: i need help{shaving of a head}
talk to a machinest. they have all the resources and information available to them right on hand. i think you will have to go with less than 30grand, but im sure you could shave some material off. let us know what they say and how it goes, cause thats the kinda stuff that we all want to know!
Reply 0
Jan 29, 2008 | 04:55 PM
what the hell is 30 grand ???? you mean 30 thou
Reply 0
Jan 29, 2008 | 06:11 PM
a grand is a 1,000....
30 grand = 30,000ths
Reply 0
Jan 29, 2008 | 06:59 PM
sohc will be ok
dohc will not be ok
sohc with dohc pistons big no no
dohc with sohc pistions ok
another interesting fact...
Did you know if you install 8.8-1 compression pistons you engine becomes a non-interface engine... you can snap timing belts all day long... lol
Reply 0
Jan 29, 2008 | 07:47 PM
Quote:
ORIGINAL: 95to96transplantneon
sohc will be ok
dohc will not be ok
interference, not interface
Reply 0
Jan 30, 2008 | 12:43 PM
does anyone know how much i can take off?
Reply 0
Jan 30, 2008 | 01:32 PM
you can safely take .040 off the head if its a stock pistons in the motor it was designed for so if you dohc pistons with a dohc head or sohc pistion with a sohc head you will be fine.
Just remember the more you shave the bigger the boomif you timing belt lets loose... So make sure you use get a new timing belt when you do this along with water pump and tentioner.
Reply 0
Jan 30, 2008 | 07:02 PM
but seriously what would the point be? to raise ur compression? you can do that just by buying the right pistons.
Reply 0
Jan 30, 2008 | 07:10 PM
oh and lets not forget that when you shave the head you retard the timing. so ur gonna have to find a way to compensate for that, like adjustable cam gears. Old school train of thought was to shave the head to increase compression, but back then it was way harder to get custom pistons. i think you would be better off just getting thehigh comp.pistons.
Reply 0
