i have a question
i just pick up a 95 dodge neon i belvie it's sohc, i have been hear u can use part for the srt neon but i hear u i have swap over to a dohc, but the prob is i live in the a small town, so i would like to know can i use ECLIPSE TALONor AVENGER motor for part like the head ect
what???
if u r trying to do an srt swap then u need the engine, wiring harness, and ecu....
as far as i know u can use a stratus 2.4 if u do not get an srt engine.....
i hope i helped
i hope i helped
Q: I heard that the Eclipse and Neon have the same engine, is this true?
A:No! The eclipse has a 420a engine and the neon has the ECC (DOHC) engine or ECB (SOHC). The DOHC neon engine was a joint venture between Lamborghini (YES, that's right) and Chrysler. Mitsubishi used the Neon engine in their non-turbo Eclispe, but reversed the head to put the exhaust manifold in the front. The 4g63 engine (turbo) was entirely designed by Mitsubishi in Japan and has no common parts with the neon.
for some reason i think you can swap the heads
this explains most of the diffrences
http://www.babcox.com/editorial/ar/eb80234.htm
ok so should stick the money into the sohc or just try to find a dohc motor or will this work http://cgi.ebay.com/ebaymotors/2-0-2...spagenameZWDVWand could u tell me what parts i will all need to make it work if it does
well a DOHC head on a SHOC block is going to lower your compression because the SHOC pistons.So not as much HP. good if your thinking turbo but if N/A better off withe DOHC pistons.
https://dodgeforum.com/m_599520/tm.htm
Trending Topics
well DOHC pistons are the higher compression type, so you wont be able to add as much boost. best stuff for turbos would be as low compression stuff, perferably forged internals
