Tach cluster in non tack Neon?
Old Feb 5, 2008 | 01:57 AM
rayraydoet's Avatar
rayraydoet
Default RE: Tach cluster in non tack Neon?
what year clusters from wat models cars does a cluster with a tach work in a 96 neon with no tach? can i use a 2000 and up cluster? and how bout possibly the srt 4 cluster will that work i dont care about my e brake light working as long as all the gauges work
Old Feb 5, 2008 | 02:39 AM
Slashwannabe's Avatar
Slashwannabe
ORIGINAL: rayraydoet
The SRT-4 cluster probably takes a bit more fabbing, but I have seen people use the cluster. Also I haven't personally witnessed it but some people say the 95 cluster is hooked up via wires and harness. My cluster out of a 95 Neon and all i had to do was unplug it fromthe dash and I took mine apart soI could have correct mileage and swapped it will my mileage counter. Then allI did was plug it in my 98 and drive. The hardest part is popping off the topdash pad.
Old Feb 5, 2008 | 07:09 PM
neoncrazy101's Avatar
neoncrazy101
95-99 is plug and play. SRT-4 and 2000+ clusters require fabby and wiring and possibly the 2000+ PCM at which would require a lot of re-wiring. People who put in the SRT-4 cluster most likely swapped the entire thing. motor, pcm, and so on.
Old Feb 5, 2008 | 08:11 PM
bone33's Avatar
bone33
ORIGINAL: Slashwannabe
ORIGINAL: bone33
what ever. take a valium. the guy has one post. he's never coming back, so im not writing a paragraph like you.
You got me so pissed I want to take myneices ice skates and stab you with them.
If you didn't mean it in a bad way then ignore what I put but if you did mean it then it applys.
settle down junior.
Old Feb 5, 2008 | 08:22 PM
Slashwannabe
ORIGINAL: bone33
ORIGINAL: bone33
settle down junior.
Sorry my painkillers for my broken nose were kicking in that day...lol
Old Feb 5, 2008 | 08:23 PM
bone33's Avatar
bone33
ORIGINAL: bone33
ORIGINAL: bone33
settle down junior.
thanks for the new sig!
Old Feb 5, 2008 | 08:50 PM
Slashwannabe
ORIGINAL: bone33
No Problem, I was sitting back a few days before that post and I watched Happy Gilmore and I was inspired to think of that and so pretty much I was looking for an excuse to use it...lol.
